More editing options for voice tracks
Bjorn
Would love to know if more editing options for voice tracks is a feature on the cards in the future? Select a region and being able to copy, paste, cut and delete would be great!
Cheers
We only plan to add select and delete region feature. I'm not sure about copy/paste options, if they are needed there - what is the use case for it?
Ah okay. I think it would be cool to be able to add audio. For example, if you've added audio at the end and you want it in the middle, you'd be able to select it and move it somewhere else in the voice track. Thoughts?
We don't really want to make Voice Track recording tool into a fully-featured audio editor :) Let's see what other users have to say about it.
Well, then you could create a new tool called "Audio Editor" for the Ultimate edition, similar to Adobe Audition Lite, but made by you, which integrates perfectly with RadioBOSS products.
Cut, paste, duplicate, record, drag and drop, adjust volumes. In short, a multi-track editor. Then everything is saved in a single file (mixdown) and played back by RadioBOSS.
You can assign markers to the session so that the titles are played correctly based on where the playback is.
I hope you get the idea ;)
One of the users made a similar request a few months ago : Record Voice Track
Perhaps there's some interest in seeing improvements to this tool. From what I understand, it would mainly be for editing with different tracks, removing interjections, speech tics from an interview, etc. A multi-track editor like the one suggested by @matteolop could be suitable.
Personally, I use third-party software for recording, editing, and also for processing the voice (compressor, limiter, dynamic range, etc.). This processing is essential depending on the hardware configuration. I'm thinking of some users who don't have microphone audio processing before entering RadioBOSS.
Perhaps this voice processing feature could be implemented in a future major update?
The idea is clear, but I'm not sure if it'll add a lot of value for RadioBOSS. For now, those improvements will be kept in mind for the future.
RadioBOSS allows assigning DSP processing for the MIC button. This processing is also applied when Voice Track Recorder is used.
Cheers
It would be great to edit out minor mistakes as opposed to re recording
