We only plan to add select and delete region feature. I'm not sure about copy/paste options, if they are needed there - what is the use case for it?Would love to know if more editing options for voice tracks is a feature on the cards in the future? Select a region and being able to copy, paste, cut and delete would be great!
We don't really want to make Voice Track recording tool into a fully-featured audio editorAh okay. I think it would be cool to be able to add audio. For example, if you've added audio at the end and you want it in the middle, you'd be able to select it and move it somewhere else in the voice track. Thoughts?
I'm always curious and interested in new features that can be added to RadioBOSSI approve, and I would like to see it.![]()
The idea is clear, but I'm not sure if it'll add a lot of value for RadioBOSS. For now, those improvements will be kept in mind for the future.Well, then you could create a new tool called "Audio Editor" for the Ultimate edition, similar to Adobe Audition Lite, but made by you, which integrates perfectly with RadioBOSS products.
RadioBOSS allows assigning DSP processing for the MIC button. This processing is also applied when Voice Track Recorder is used.I'm thinking of some users who don't have microphone audio processing before entering RadioBOSS.
Perhaps this voice processing feature could be implemented in a future major update?
We don't really want to make Voice Track recording tool into a fully-featured audio editorLet's see what other users have to say about it.
It would be great to edit out minor mistakes as opposed to re recordingWould love to know if more editing options for voice tracks is a feature on the cards in the future? Select a region and being able to copy, paste, cut and delete would be great!
Cheers
Selecting regions and removing them will be possible in one of the future update.It would be great to edit out minor mistakes as opposed to re recording
When it then switches to the Main and another DSP is used, a double process is created, and I don't think that's a good thing.RadioBOSS allows assigning DSP processing for the MIC button. This processing is also applied when Voice Track Recorder is used.
