BUG RadioBOSS 7.1.6
matteolop
Hi, I just updated to the latest version and am having a problem.
When I double-click on tracks in the playlist, the pre-listening/monitoring starts (correctly), but the song starts from point 0 and not from the IN point set by TrackTool.
This does NOT happen on all tracks, however.
Also, why don't the > < arrows for moving forward/backward from the LOG tab appear when I double-click to monitor/prelisten, and why are some options grayed out?
Also in the LOG tab, when I click "Show in Playlist," what exactly is it supposed to do?
In my case, nothing visual happens.
This behavior was not changed in the past few versions.
To clarify, some tracks start at the defined Start point, and some not?
Those hot keys (<>) are not defined for the Log tab. I think more information is needed on this. Some options in the Prelisten window are only available when it's started from playlist, and not available if started from the Log.
It will scroll to the playlist item.
and it happens to me, can you check?
This is what it looked like during pre-listening, but in reality, they start well from the original track, or there's little silence at the beginning.
But for older songs with a long intro, I'm sure I set the starting point to about 10-20 seconds into the track.
So, pre-listening, you can now hear it from starting point 0.
Ok I understand, I just needed this confirmation.
It doesn't seem to happen.
Perhaps it wouldn't have been better to make it "flash" so I could find it?
How does Windows, for example, handle the icons in the taskbar?
Yes, same happening to me. Some stongs start at zero, even though I have set to higher number. The seconds silence is driving me insane..
I assume I can rollback firmware? Is there instructions
Yes, I'm doing it too tonight, until the staff fixes it.
Download the previous RadioBOSS .exe file from the official website and overwrite the installation folder.
To be safe, I do a daily backup.
I think it is also ignoring some intro points too, setting the intro point to Zero on some tracks, causing the voice track to finish at zero instead of set intro point..
Can you explain it to me better? Because I use white vocals a lot on the intro of songs, and so far, I haven't heard any anomalies.
Ok. I have 5 voice tracks per hour. In the last hour I heard voice track before a Jimmy Somerville, you make me feel, It started at outro point of previous song and finished at Zero point of You make me feel.
I am not in front of radioboss, but I am pretty sure intro point is around 20 secs.
My voice tracks are set to start at Outro point of previous song.
OK, I confirm: I think something's preventing the set reference points from always being read. During the 30-minute drive home, I had the opportunity to listen to the radio, and some things didn't add up. Some songs would start at a different point than I'd set.
Checking this does indeed confirm an error. If the Start point was further than certain position, a track started near its beginning. This will be fixed shortly in the hotfix.
It will center this track (vertically) and also select it. So this is prominent enough. This only works for the items that did play in the current session (when RadioBOSS was open).
I think more details are needed about this.
Can you please post a screenshot of the VoiceTrack settings section? Also did you set any voicetrack-related options in the Advanced section?
After installing version 7.1.6.1, this error message appeared when I opened Music Library. Other applications opened normally.
To resolve the issue, I had to switch from my administrator profile (full access) to a user profile. Switching back to the administrator profile eliminated the error message.
The behavior is correct. Now in this version: "This will be tweaked and direct Playlist Generator launch will only be prevented if one or more users do not have "Playlist Generator" permission" by djsoft staff
