BUG RadioBOSS 7.1.6
The mix point is called MIX and highlighted marker on your screenshot is actually Mix Start, it has a different meaning and is explained here: https://manual.djsoft.net/radioboss/en/track_tool.htm
Okay, but explain to me why some songs mix only halfway and others don't. There must be a problem.
It's not normal for some tracks to mix "normally" while others, like the ones I mentioned, only mix halfway, as I showed you in the image. As I said, I've disabled the mixes and it works "fairly well." Thanks and regards.
On the image the actual MIX point is at the end, this is where a track will be mixed (unless this mix point is overridden by Segue Editor or File Types). Where a song is mixed depends on its own configuration but also on the following track (its MixStart value and if it has "Override previous track mix point" option).
Hi, fade-ins that don't follow the tracktool points set are still present in this version of SegueEditor.
I remember you fixed it in the last release.
Currently there are no open bugs for Segue Editor regarding points not being correctly processed - so more information is needed on what's not working for you.
Here's what happens.
I'll post a screenshot.
When you set certain mixing values in the Segue Editor, those changes will not be visible in Track Tool.
Also, on your screenshot is a gap between tracks (second track has "End" mark, then nothing, and then 3rd track starts later) - on playback, this gap will be removed.
When no Fade In is set in Track Tool for a track, when you open a Segue Editor, it will use the default Fade In value as set in the Crossfades window.
