Schedule exception ?
Tekno1 Radio
Hi RB Members ! Happy New year !
How can I prevent a specific event from playing every Saturday at 7:30 PM when it repeats every hour and every day of the year? I don’t see any exclusion features.
Thx ;)
You can use the "Hours" option and select the hours when you need to run the event.
Hello and thx for reply.
The problem is that if I skip one hour to prevent the event from running, it will do so for every day of the week. I just need the event not to be executed on a specific day at a specific time.
Its ok ;) thx.
It can be solved by using the multiple start times, as you did, or creating a different event (a copy) that uses different start times for a specific day of week.
