Request for More Precise Cue Points
RadioMaxx
I would like to request an improvement to the cue point precision in the track tool.
At the moment, cue points seem to be limited to 0.01 seconds. I would like them to be more precise, for example 0.001 seconds, so cue points can be placed more accurately.
It is also important that cue points trigger exactly at the saved position, without any delay or timing offset during playback.
This would be very helpful for users who need precise timing in their workflow.
Thank you for your time and consideration.
The points are triggered with sample accuracy, and this can't be further improved (for 44.1kHz file it's 1/44100th of a second - so shouldn't be a problem). As for .001 precision, what is the practical use for it?
It would be a great improvement if the precision for start and mix points could be increased. Currently, the 0.01s adjustment steps in the Track Tool feel a bit too coarse for professional use, as even a tiny timing difference is noticeable when trying to hit a kick drum exactly. Updating this to allow for 1ms (0.001s) increments would make a big difference in achieving much tighter transitions, a feature already standard in competing software which allows tracks to begin at the exact millisecond.
Along with finer steps, it would also be very helpful if the waveform zoom could be increased. Higher zoom levels would allow us to see the transients more clearly, making it much easier to place cue points accurately and get consistent, professional results on air. (y)
An interesting suggestion for musical transitions requiring particular precision—especially snare drums.
For your information, there's a difference of 3 to 4 hundredths of a second (0.03–0.04 seconds) between the "Mix" point indicated on the Track Tool waveform and the playback in the Playlist.
I mentioned this last April in a comment on a discussion thread by @matteolop .
According to the response at the time, and after testing the preload time, an option was added in the advanced settings to account for this delay.
I haven't found it in the latest version of RadioBOSS.
What is the name of the line, if it exists? Is it possible to allow for delay correction to the millisecond?
Being able to set precise cue points makes a big difference when mixing and preparing tracks. When cue points aren’t exact, it can throw off timing and transitions. Many users find that zooming in on the waveform and using keyboard shortcuts helps improve accuracy. Clear feedback to developers also increases the chance this feature gets refined.
Technically it can be added, it's only a UI thing, as inside all those settings are stored/processed in milliseconds.
This will be possible in RadioBOSS 7.2.
It was in versions 5.9 and earlier, now all points are triggered immediately with sample precision. There may be some time delay, but I guess it should be under a millisecond, the time required to register playback position and then perform action/thread synchronization.
Hi, so as not to create a new ticket, since the problem is similar: some MP3 files (which I can only send you privately if you wish) are played correctly on air and the transition to the next track occurs at the mix point set by TrackTool, but on the playhead the red MIX mark doesn't match and is often out of sync with what I hear.
Why does this happen?
For privacy reasons, I can't attach videos/images publicly here.
How much is it out of sync? AFAIK seeking/positioning in an mp3 file is not very accurate, mp3 consists of frames so precision may be limited to one frame. Still, it's under 5 milliseconds or so I guess.
You can try converting the same file to WAV and see if it performs better. But technically, all points are triggered with no delay. That's why I also suggest to check if the Mix point is in the right place.
Yes, exactly. The mix mark is shifted by just a few seconds.
In any case, the playback is perfect.
Do you think this aspect could be improved?
A few seconds does sound a lot. I think more information is needed on this, how the track is configured (a Track Tool screenshot) and a track itself.
Are you sure it's not something else, e.g. the following track has Mix Start set - it will affect the playing track mixing position. Or maybe the tracks are edited in Segue Editor, or there are File Types involved with "Override previous track mix" - it will also shift the Mix position.
RadioBOSS shows Mix position as red line in the Nowplaying box, does it start mix at this marked position?
I can't really measure it, certainly less than one.
I attached the video with the demonstration.
I'm sure I've never activated/used these features.
RadioBOSS shows Mix position as red line in the Nowplaying box.
Yes
No
https://we.tl/t-PfWZfGIXkW
Yes, because, for example, it would be more visually convenient.
Look at how beautiful and precise it is in Adobe Audition, and look at how limited RadioBOSS is.
You struggle to figure out where the kick is.
I often find myself testing a song/jingle more than 10 times to find the right hook.
I would like to ask if there is any way to avoid delays of up to half a second during mixing, even when the program is not using full processor power at set High priority in Settings.:unsure:
I would also like to ask if it is possible to zoom into the waveform at millisecond level, so it can be seen more clearly. This would be helpful not only to set values from 0.01s to 0.001s, but also to visually place cue points more accurately.👁️
With these improvements, everything would be fully ready for precise mixing. Thanks in advance! :love:
I propose a solution similar to this, to get a lot of precision on any audio element present on RadioBOSS :cool:
will it be possible on version 7.2?
I don't think it's activated earlier than the mix point is defined. The track is short and mixing occurs before the graphics can catch up. Graphics precision is around 50ms (a bit more actually), so it may be off - but it does not affect playback.
The core of this is that RadioBOSS targets automatic mixing mostly, therefore Segue Editor is not as fully functional as in software that targets manual mixing, or professional audio editing software. I think zooming range can be improved there, to improve things.
There are no delays in triggering the Mix point. Track loading can take some time - but by default, preloading is active, so by the time the next track is supposed to start via the Mix point, it's already ready to start immediately.
Zooming range in Track Tool will be extended in the next update.
RadioBOSS will offer 0.001 precision as an option (we'll start with placing this option in the Advanced section). On your screenshot it seems to be frame precision, but this design won't fit into Track Tool because it has lots of time input fields, and having them this big will not look good.
If I convert from MP3 to WAV with reaper, overwriting the files in question, do I lose the cue points I set?
When you convert from within RadioBOSS, it will copy the additional information. If you perform the conversion externally, it will not be copied. Renaming the converted WAV file to MP3 extension, will preserve the information, but it's not a good idea. Also there's no point to convert MP3 to WAV anyway :)
