DTMF Tutorial
rrieke
is there a detailed tutorial to implement separate Commercials on 2 stations? I know its mentioned in the manual but elementary instructions are missing.
we originate live programing at one station and use RB for commercials, promos, ID's etc. The output of the console will then go to the second station. This feed contains all programing. when a StopSet is played, we need the DTMF to trigger a different StopSet at the second station, and rejoin the originating at the end.
I'm new to RadioBoss so as much detail and simplicity as possible is necessary.
thank you.
Rick
If those are two different stations, each with its own commercials, then you should install two instances of RadioBOSS and consifure each one separately. If you want to manage ads remotely (from one computer manage two stations) then also install it into two different folders, and use the remote ads management feature: https://manual.djsoft.net/radioboss/en/remote-ads-management.htm
RadioBOSS can both generate (play) DTMF tones and detect them. On the main RadioBOSS installation you should make it generate DTMF tones (menu Playlist, Extra, Add DTMF tone generator) and send this stream to the stations. Stations will detect those DTMF tones to start the scheduled events: https://manual.djsoft.net/radioboss/en/starting_events_by_dtmf_signal.htm
