RadioBOSS 7.2 [beta]
is it possible to start a timer earlier than just a few seconds?
For example, for a timer set to start at 12:00, and the previous playlist ending at 11:59:56 AM.
Thank you for your reply.
Sincerely,
Loic
this eppears wenn adding a VST plugin
RB is 32 bit
Win 10
Time Stretching only applies to music tracks. These are the only elements whose playback speed can be adjusted to allow other segments (host, reporter, commercials) to play/speak at their scheduled times.
I'm not sure yet how we'll proceed with this. Presently, the general idea is to add Speed configuration in Track Tool to make a fixed adjustment of track's playback speed (similar to how "Playback level" works) and then a temporary configuration may also be added for playlist, to configure the playback speed for one playout (similar to how "Segue Editor" works).
The same thing: SQLite and I get a similar result regarding the letter "a" / "à".
This is not the same in the search results. And I use the mouse.
Thank you, the search and next track issue will be checked.
It appears that in this beta version there is no indication that the Relay is active. In previous versions, the Relay status was displayed in the On Air window. Currently, no information is shown to indicate whether the Relay is connected or disconnected.
Thank you, this will be fixed in the next update.
I am testing the new beta version of RadioBOSS, and it should be possible to choose post/pre listening on the mixer, so that you can also hear what is on the different channels before sending it on air. Basically a kind of cue function that lets you pre-listen to the audio from, for example, Line 1 before broadcasting it.
Thank you for the suggestion, I think this will be added in one of the next updates.
I have a category of tracks in my library that are in italics in the playlist. Why is that?
Have a good day.
RadioBOSS marks voice tracks in italic font. In your case, either those tracks reside in the voice track folder, or you have defined a file type with "Treat as a voice track" option and all tracks of that type will be marked in italic font because of that.
I love the feature where playlists can be generated before events, given that radioboss can predict the start time of tracks, would it be reasonable to have the playlist that is generated early to be inserted in to the main playlist so that its content will play at the time of the event? This would also give radioboss time to work out sweepers and the amount of time compression necessary to get things started as soon as close to the start time of the event as possible.
I think sweepers can be applied in this case - but as the actual command starts earlier, it should apply sweepers based on event's start time. I think this adjustment will be applied soon.
Small deal, maybe a bug, maybe just because it's beta. In the bottom bar, the icons of programs that are open get a bar underneath, the app in the foreground gets a larger bar. Radioboss has nothing, no matter the focus. In the screenshot Radioboss is the active foreground window.
It depends on how you added it to the taskbar. If you have added the default shortcut there, it opens launcher (not RadioBOSS directly), so the underline may not appear. You can fix it by removing the RadioBOSS icon from taskbar, then start RadioBOSS, and right-click its taskbar icon and select "Pin to taskbar".
You can achieve this by setting the event's start time to 11:59:56 AM I think.
RB is 32 bit
Win 10
The error is inside the plugin's DLL so it's either a bug there, or some sort of weird incompatibility with RadioBOSS. I don't think much can be done here from our side.
Yes, I know that the hourly top can be triggered at 11:59:56 AM, but in cases where the hourly top is at 12:00 PM and the previous playlist ends at 11:59:56 AM with the tracks stretched, couldn't the 12:00 PM top be triggered automatically, with a maximum delay that could be set by the user?
For Dayparting to work, you will need to always specify the playlist start time. This means, updating all the events that generate the playlist, adding the start time there. Or, if you use the Generate Multiple Playlists window, specify the start time there. Please note that start time specified there is for the first playlist, the second playlist will have its start time as [configured Start Time] + [first playlist duration], third playlist will have its start time as [configured Start Time] + [first playlist duration] + [second playlist duration], etc.
Thank you for these detailed explanations. That's good to know.
If I only have one playlist to generate from Playlist Generator, I click on "Generate." That was one of the two previous examples.
Where do I set the playlist start time for Dayparting to work? I can't find it.
I suggested inserting this start time in the "Settings" tab of Playlist Generator.
But that would create a default start time that would conflict with scheduled events where other start times are defined. Perhaps add an "automatic reset" option: as soon as "Generate" is clicked, the start time becomes grayed out again.
By using "Generate multiple playlists", it's possible, since version 7.2.0.2, to define the start time (and day). And for generating a single playlist, it works.
But it's a bit time-consuming to go through this step. Furthermore, this makes no sense for generating a single playlist.
Yes, the general idea is good.
Besides music tracks, could this be extended to other file types? For example, to adjust the length of a film review.
Yes, a "Sequence Editor" option for Time Stretch. Two fields could then be displayed:
  • Duration of the original track: hh:mm:ss
  • Duration of the desired track: hh:mm:ss
Upon confirmation, the Time Stretch value (%) is automatically calculated and would also be displayed in the "#" column of the playlist.
I’ve mentioned this before, sometimes when I’m talking between two songs, an intro suddenly starts under me. I’ll be speaking live and - boom - the intro kicks in unexpectedly.
I really like the new Manuals option so commercials can’t surprise you when I talking. That’s a great improvement.
Maybe when Manuals is enabled, Auto Intro could also be temporarily disabled? So whenever you’re in manual mode, nothing can suddenly start under your voice.
That would make manual/live work feel much safer and more relaxed.
And one more small idea.
Since there’s already a clock there, maybe it could be possible to make it flash a few minutes before the top of the hour or half past the hour. That’s usually when news or something important starts on radio, so it would be a helpful reminder.
Something similar to how it flashes before commercials - just as a visual heads-up.
Maybe just a couple of simple options:
– trigger at the top of the hour or/and at half past
– choose how many minutes before it starts flashing
Nothing complicated, just a small configurable reminder.
Does Dayparting work with automatic playlist generation + load command?
My current workflow is:
  • I use a Playlist Generator preset.
  • RadioBOSS automatically generates a playlist every hour.
  • Then the playlist is loaded using a “load” command.
  • Several tracks have Dayparting configured.
With this specific workflow, should Dayparting work or not?
If it does not work this way, what would be the correct approach?
Is it necessary to:
  • create scheduled events with a specific start time for each playlist,
  • use clocks,
  • or generate separate playlists for each time slot?
Should I work in a different way if I want to use Dayparting properly?
I’ve done some tests and, as far as I understand, for my workflow, which is intended to use dayparting, each “generate” event (to be later loaded with the “load” command) would need to be duplicated every day, right? Because for each estimated start, you have to specify it when generating the playlist using the “specify playlist start time” option for each day.
So, would this mean I would end up with a lot of scheduled events? (Which I want to avoid).
Is there any way or option so that:
  • My patterns, which are generated one at a time every hour during the day and every day (3 patterns in total), respect dayparting and, at the same time, I don’t have to create too many specific events for each day of the week with the estimated day and time in the “generate” command?
I’m not sure, but is there an option to make the “generate” command the same for each day, or am I wrong?
i am using exactly the same plugins as in version 7.1
Hi everyone. I would like to provide feedback regarding the 'Create multiple playlists' window. This window is still only semi-accessible.
For the buttons, NVDA just says 'button' and doesn't read the specific option or label. The only options it correctly announces are: 'save playlist to', 'number playlists for each preset', and 'start number'.
Also, when the presets option is opened, it is not possible to check or uncheck the desired preset (the checked/unchecked state is not announced). The checkbox for specifying the playlist start time is readable, though.
I hope you will be able to fix these issues.
I think it will work like this if you simply set the start time at 11:59:56. Or is it not?
If you generate using the Scheduler, then when you edit an event, use the Wizard, select "Generate a playlist" and it will allow setting the start time.
Usually the playlists are generated automatically by the scheduled events, and you can set the Start Time there. Manual "Generate" button is for testing the template mostly, not for real world operation.
Track Tool allows to edit any tracks, file types or not doesn't matter.
Noted for the future versions.
Do you refer to Auto Intro? If so, it shows a countdown before it starts. Of course it doesn't cover the case when it starts immediately with/before music track. For this, the upcoming feature (but probably not in this beta) will be added to show Auto Intro in the Next Track bar, allowing to cancel it.
Thank you!
Yes, this can be added, I think as an option.
Will be added in the future versions.
It will work, but you will need to update all your events that generate the playlists to include the Start Time information. For this, edit an event, use the Wizard, select "Generate a playlist" then select preset, where to save, and set start time information.
Each time slot will need to have its own event because the start time is different for each time slot.
I think we may add an option so that if no start time is set, it will use the current time, but I think it may lead to unexpected behavior in some cases and is not really correct.
Start Time means you need to select the start time and also day of the week. I'm not sure of what the solution could be so to set the start time automatically. There's a new tool we plan to create that will allow automatically manage those "generate playlist" events, but it will be released later.
Plugin handling was not changed in 7.2 compared to 7.1. Maybe the bug was always there but due to changes in other parts of the software, as a side effect, the bug now manifests. Maybe you can try a different (updated) plugin version.
