Daylight Saving Time Change
urbanique
We enjoy running our web radio station, supported by RadioBoss Cloud.
This coming weekend, on March 29, 2026, the time will be moved forward by one hour.
Our server is currently set to UTC +1.
Question: Do we need to manually adjust the settings, or will your cloud system handle this automatically?
It is handled automatically, but you have to select the correct time zone, not all UTC+1 time zones are equal (so do daylight savings, some not, depending on the local regulations). You should select the one for your country/city.
