Generated playlist commands to allow events scheduled to play on scheduled time.
Eresto
Hey there, I generated playlist and I have scheduled events to play in between the playlist songs but when the event scheduled events plays then the playlist disappears completely. What would be the best commands to handle generated playlist and the events scheduled work together without interruption or interferences?
Your Playlist:
In "Event," select "Insert as: Scheduled tracks"​
Your scheduled events:
When a scheduled event is launched, it's possible to remove a playlist if you have selected one of the options in the "Insert position" (Event) section:​
  • "Replace playlist"
  • "Replace scheduled tracks"
Also in the Ads scheduler:​
Block setup > Event properties > Insert position. If you have selected "Replace playlist" or "Replace scheduled tracks," all the elements​
/ elements in your player will be removed to play the ads.​
You need to select another option: "Queue after the playing track".
Therefore, your playlist will remain in the player and your scheduled events will play at the scheduled time after the currently playing track.
Looks like the events that start have "Replace playlist" or "Replace scheduled tracks" enabled. Please also consider using the "Insert as music tracks" for the generate playlist events.
You can find more information about the options here: https://manual.djsoft.net/radioboss/en/eventoptions2.htm
