RadioBOSS 7.2 [beta]
Friends, when will we have this new version 7.2.1.1 finalized and ready for everyone to do this complete upgrade? I'm anxious for it, you have no idea. Tell me?! Friends, when will we have this new version 7.2.1.1 finalized and ready for everyone to do this complete upgrade? I'm anxious for it, you have no idea. Tell me?! I WANT TO USE AND PROMOTE THE SOFTWARE IN MY COUNTRY AND TELL MANY PEOPLE THAT THIS IS THE BEST, PERIOD.
I just retested and can confirm the issue is permanent, not occasional. It consistently occurs on auto intros that end at the fade-in point.
I also tried setting the fade time to 0.1 as suggested, but unfortunately it makes no difference — the problem persists.
Hi,
I get a different playback rendering depending on your Auto Intro settings (Rule • Position on track: End at "Fade in"): The vocal track and the track start at the volume defined in the settings (Playback > Fading > Auto Intro) and this volume increases until the "Fade in" point.
No difference if the Fade 0,0 or 0,1 second.
Please let me know if you need any additional information or logs to investigate further.
Thank you. Yes, we have confirmed and fixed it here, the next update will have this resolved.
This would require it checking in the background (periodically) what files actually exist and with a large number of card walls it may consume some resources. How often is this is an issue?
For us, quite often - filenames change frequently which break connections on the cart walls, and like we have 50 odd cart walls for each of our presenters, we can’t go in and update them all.
Regarding checkin on RadioBOSS open, maybe it checks when the tab is active instead? Or when a card wall is loaded using the load function. We don’t ever close RadioBOSS so checking on open wouldn’t help too much…
There's no set date set for the release. We need to fix everything first to ensure the release has as little bugs as possible. But there are no open critical bugs so this beta is acceptably safe to be used in production.
Hi,
There is a bug when an Auto Intro starts before the music track, and fading was wrong in this case sometimes. An update will be released soon to fix it.
Checking 50 cart walls could potentially be a performance hit. I'll add this to the requested features list, probably will be added in this beta. I think the most effective check would be on tab switch + periodically like every 10 minutes.
The track information (Artist – Title) is not being sent to the "nowplaying.txt" file when the track is played from the Cart wall slot and AUX Playlist.
Is it possible to add an option (either in the settings or advanced settings) to allow the information to be sent in the same way as in the player – playlist ?
By respecting the properties of each file type (broadcasting title). Or does this already exist?
I think it has already been reported, but there are issues with the volume of songs that have an auto intro. When the auto intro ends, there’s a noticeable drop in the music volume, beta 7.2.1.0 and 7.2.1.1
Yes, this is the correct behavior. The titles are only saved/sent from the main playlist. Both of those items are supposed to play on top of what's playing in the playlist, without overriding its title. We do not plan on adding an option to send titles from Cart or AUX, I'm sorry.
This bug will be fixed in the next update, thank you.
Added scaling (zoom) option for the main window. Where is this? Screenshot please.
Settings window, View > Style.
I think it's a good idea.
Or even develop real players for live antenna capture because not all radio stations broadcast in automation all day, we sometimes have interruptions for live events such as a sports broadcast, a debate...
Maybe it would be possible to integrate players in a future version?
Music Library (Columns)
Is it possible to add elements to the translation file?
Select Columns​
Cancel​
Dayparting​
RadioBOSS 7.2.1.2 beta
Changes
  • Auto Intro: fixed music attenuation bug
  • Fixed: occasional crash when actively moving/renaming/deleting tabs
  • Cart wall: non-existent files are marked with red "error" label
  • Fixed: dayparting for Auto Intro and Track Tool sometimes did not work properly
  • Hour Markers in the playlist: minor bugs fixed
  • Track Tool: right-click menu commands to copy parts of a filename
  • Minor improvements, bugs fixed, updated translation files
x86 https://dl.djsoft.net/beta/radioboss_setup_7.2.1.2.exe
x64 https://dl.djsoft.net/beta/radioboss_setup_7.2.1.2_x64.exe
For this you should use the other playlist tabs, or load it to the main playlist tab. Also, scheduled events with the "Overlay playback" flag can also sent their titles, but it needs to be enabled in the settings: https://manual.djsoft.net/radioboss/en/schedule_settings.htm
I don't think sending the titles from cart wall make much sense, carts are designed to be quick effects playing on top of the main content, changing the title from there seems unexpected. Same, for a lesser extent, is true for AUX players.
Virtual Mixer Board: an interesting and useful option.
The virtual console display in Dark mode lacks aesthetic appeal in my opinion (Virtual Mixer.png): there's insufficient spacing between each channel strip, and the separation between them isn't pronounced enough.
It creates a uniform block, and it's not immediately clear whether the fader corresponds to the left or right VU meter.
Suggestion – see screenshot based on VoiceMeeter (Fader Gain - Name.png):
  • Move the fader and VU meter closer together. This will allow for better focus on the desired channel strip.
  • The fader bar: wider, with customizable channel strip text displayed horizontally and vertically for quick identification.
  • Text: the ability to rename each channel strip. Aux 1, Aux 2, Input 1, Input 2… This isn't very user-friendly when multiple sources need to be managed quickly.
Is it possible to add the text "Virtual Mixer Board" to the translation file?
Good observation Guillaume. Good day to you!
Hello
Every time you make even the slightest change in the settings, this pop-up message appears.
This is very annoying, especially since the changes are saved even WITHOUT restarting RadioBOSS.
