Error loading input plugins: bass_ac3.dll
MrWeggla
Hello, I updated my RadioBOSS from version 7.1.5 to version 7.2.1.8 today. Now, every time I launch the program, the following appears in the log window: Error loading input plugins: bass_ac3.dll
How can I fix this?
RadioBOSS x64 Standard Edition
Windows 11
Thanks for your help.
How can I fix this?
Windows 11
You're not the only one; several users have reported issues with bass_ac3.dll and bass.ape.dll.
These files are not included in the 64-bit version, but they are present in the 32-bit version.
You might want to copy them from the 32-bit version and paste them into the 64-bit version under “Plugins.”
du bist nicht der einzige, mehrere user haben probleme gemeldet mit diese bass_ac3.dll und bass.ape.dll
Diese sind in der 64 bit version nicht enthalten in der 32 bit version sind diese dll da
Vielleicht aus der 32 bit version kopieren und in der 64er einfügen bei plugins
Notfalls kann ich dir diese dll s zukommen lassen
Thank you for your prompt reply.
However, both of the *.dll files you mentioned are present in my Plugins folder. What I did notice is that the `bass_ac3.dll` file bears a date from 2012, whereas all other *.dll files in the Plugins folder were updated during the update to V7.2.1.8. Could this be the cause—that this specific file is outdated?
If you could provide me with your copy of the file, that would be very kind.
Kind regards
Ich Danke Dir für deine rasche Antwort.
Beide erwähnten *.ddl Dateien sind aber vorhanden in meinem Plugin Ordner, was mir auffällt ist, dass diese bass_ac3.ddl ein Datum aus dem Jahr 2012 aufweist, alle anderen *.ddl Dateien im Ordner Plugins sind aktuallisiert worden beim Update auf V7.2.1.8. Kann es daran liegen, das diese veraltet ist?
Wenn Du mir deine zur Verfügung stellen könntest, wäre das sehr nett
Freundliche Grüße
How can I fix this?
Windows 11
In this case, the plugin didn't load in previous version as well. Version 7.2 just adds the error message when it happens (version 7.1 silently ignored it). If you don't have a need to play AC3 files then you should delete it from the Plugins folder - right-click the RadioBOSS shortcut, Open Containing Folder.
Copying a 32-bit plugin file into a 64-bit version wouldn't work as the architecture is different and it will give an error.
Hi
MrWeggla​
Ich habe da keine Fehler Meldung aber das Liegt wohl auch daran das Ich mit Codecs und Codec dll auf dem laufendem bin und auch damit ganz anders umgehe wie zum Beispiel das in meinem Radio Boss Ordner auch Codecs z.B. vom Frauen Hofer Institut integriert sind 😉
Ich lade euch mal 3 Bilder aus meinem Radio Boss Plugin Ordner hoch .
Google Übersetzer :
Hi MrWeggla,
I don't get any error messages, but that’s likely because I keep my codecs and codec DLLs up to date and handle them differently—for instance, I have codecs (like those from the Fraunhofer Institute) integrated directly into my RadioBOSS folder. 😉
I’m uploading three screenshots from my RadioBOSS plugin folder for you to see.
