Streaming Statistics by Broadcast Radio - error
liga
Good morning — in addition to the apostrophe bug reported earlier, I have another problem. For listener monitoring I rely on an external application that has always worked perfectly: Streaming Statistics by Broadcast Radio. With an Icecast server and the mount point /autodj, everything worked flawlessly. After switching to Zerocast, it no longer works. What solution do you propose? Is there an alternative to that mount point?
Thank you for your reply. Kind regards.
liga, Radio Febbre - https://www.lafebbre.ch
It's fixed with RadioBOSS Cloud 3.1.1 release.
Zerocast exposes the same API endpoints as Icecast does
  • /admin/listclients?mount=...
  • /admin/stats
So it should continue working as it did. Do you know what APIs they call to check the stats? You may contact their support and ask about it.
Dear Support Team,
Thank you for your assistance. I have confirmed that the apostrophe bug has been successfully resolved.
Regarding the statistics issue, I have conducted further investigation. While the API endpoints for listener data appear to be backward-compatible with Icecast, there seems to be a discrepancy in the date format returned by the server.
I am forwarding this information to both you and the Streaming Statistics development team, in the hope that it helps identify the root cause of the compatibility issue. The error consistently triggered is:
"0x80131537: Stringa non riconosciuta come valore DateTime valido" (String was not recognized as a valid DateTime).
It appears that the application is struggling to parse the date/time string from the current API output. Please let me know if you need any additional logs or technical details from my side to help resolve this.
Best regards,
liga
Radio Febbre - www.lafebbre.ch
The /admin/listclients?mount=... API is not supposed to return any date/time values, so it seems they call /admin/stats and parse some field with date/time string. Zerocast does not offer any date fields in this API call result. Some Icecast versions do, e.g., stream start date, or server start date. This information doesn't seem very useful, so I suppose the service you use should just ignore if those fields are not present or empty.
If there are some useful date/time fields that help with statistics, we can add those of course.
Thank you for the explanation. I have forwarded the information to the developers. As soon as I have an answer, I will update you. Kind regards, see you soon.
liga
Good morning, I am forwarding the response from the Streaming Statistics developers:
"It seems the "zerocast" server as used by Radio Boss does not provide a value of either "server_start" or "server_start_iso8601", which is required by our Streaming Stats software, as you can see in the screenshot below:
The Icecast documentation for these values is at https://www.icecast.org/docs/icecast-trunk/server_stats/ (about halfway down the page).
So it looks like Radio Boss / "zerocast" is a non-standard custom version of Icecast.
What it does provide is the value "uptime_seconds", although we cannot use this value without creating a new version of the Streaming Stats software, so until this point Radio Boss streams are incompatible with Streaming Stats."
Do you think this can be resolved in some way, without having to revert to Icecast? Thank you for your support.
Best regards,
liga
Zerocast was updated to include those fields. Please restart the server from the System area for the changes to take effect.
Yes, the statistical software is now working again.Thank you very much for your support and for your work.
Kind regards,
liga
