Assign Unique IDs to Tags for seamless renaming
JeanXeb
Hello RadioBOSS team,
I would like to suggest a highly useful feature for a future update regarding how tags are handled within the software.
Currently, it seems that tags are linked entirely by their display name. If I need to change or correct the name of an existing tag, the tracking is completely lost. The old tag name remains everywhere else (in the music database, Playlist Generator Pro, etc.), which breaks the workflow and requires a lot of manual corrections.
It would be helpful if each tag was assigned a unique, hidden identifier (ID) in the background.
By linking tags via a unique ID rather than their text name, we could safely rename any tag at any time. The new name would automatically reflect across the entire database and Playlist Generator without breaking any existing rules or links.
Thank you for your continuous excellent work on RadioBOSS and for considering this enhancement!
Best regards,
Yes, this is a known limitation/problem with the tags. Wrong design decision was made when this feature was first added (unique IDs should have been used, as you propose, not direct linking by name).
I'm afraid it's too late for that. Because it'll break compatibility, problems will arise when upgrading/downgrading between versions with different storage methods.
Currently I see no viable solution for this.
I understand your issue, I see what you mean.
Maybe, at first, you could simply do it the same way as when changing the color of a tag: you keep the initial tag name as the ID, and use a secondary name that updates.
The initial name would then act as the ID, and the secondary name would be its visible form.
Great Idea.... I have to change all my clock when I'm renaming a tag, 1hour work omg.
Best regards
Yes, this is why tag renaming should be generally avoided. We'll explore the way to move tags to using the IDs instead, but I think it'll either be for the next major release, or maybe released earlier as a mini-beta.
