7.2.2.0 FLAC & OGG Streaming Problem
easace
After upgrading to version 7.2.2.0, we started experiencing playback issues with the FLAC audio stream. The stream fails to play or load properly via web browsers (web players) and certain third-party media players. This issue was not present in the previous version. We suspect it might be related to the audio encoder changes or metadata handling introduced in the latest 7.2.2.0 update.
Rocket Streaming Audio Server
Media Player Classic
Thank you for the information, we'll check what could be wrong there.
And update on this. The stream works fine on Icecast or Zerocast servers with both FLAC and OGG format. If you use "Rocket Streaming Audio Server" perhaps the problem is there, maybe the server doesn't properly handle logical streams for Ogg-containers (or maybe the server is not properly configured - you should contact its developers about it).
I've spent some time troubleshooting the issue, but I haven't been able to resolve it. Icecast is not working reliably (the software is completely crashing), and the title updates are causing issues with some media players. How can I download a previous version of RadioBOSS?
You can download it from the customer area: https://www.djsoft.net/customer/
What players are having the issues? Everything we've tested works fine. Looks like a problem with the server you use, not the players.
PlayerStream Title Behavior
foobar2000The stream title is displayed and updates correctly.
PowerampThe stream title is displayed but does not update.
Media Player ClassicThe stream title is displayed but does not update.
VLC (Android)The stream title is displayed, but each title update causes brief audio stuttering.
