Relay Feature
Is there a way to set a duration for when a relay is running. For example set the relay to run for an hour and then cut off or stop. Using only one event. I realize that the duration limit doesn't stop it at all.
eg. relaystart https://streamurl/8000/live #3600
I also saw where when a relay is active it doesn't send the meta data information for that event. In comparison to if i create a event normally without the relaystart option infront of the url.
Yes, this is by design - when the relay is active, it will send the titles from the relay.
