Songs in playlist are beinign skipped
Radio-Albena
HI all,
Siche I updatetd from 6.3.3.0 version to 7.2.2.0 I have some strange problems.
I have generated several playlists an the weher picked random by a event every hour.
The lists have about 20-30 songs inside, all working, I have checked this, but Radioboss just skipps some of them, in the log file he shows them as normally playedd but he did not play them?? Very strange.
No I found something stange in de sound sertings Radioboss ah setting to play 44KhZ in the wondow soundsettings stood 48kHz I changed this now , but i do not know if thiss could be the problem.
second issue was the teaser, this one worked perfect in version 6.3.3.0
Now I had the same event for a teaser, openings sweeper, transition, end sweeper.
Now he skipped also the teaser a I found out that he needs too look further as the 3 preview tracks I want to have, enough tracks where in the list, but still he did not play it, as I set the max tracks to look ahead to 8, the teaser worked again, but not the next 3 tracks , he just picked some from the list. I saw there is no option to set he should pick next 3 tracks just trackcount 3. Is this option hidden sonwhere else or removed?
Now i hear 2 songs playing at the same time , this is very weard
I don't know how it's possible, if the logs show that the song had started, then it had started; if it played depends on what happens next, e.g., a scheduled event that starts next, can make the song skip. You should check the Logs to see what happens.
Sample rate does not affect anything regarding song skipping or scheduling.
Teaser will either play, or it'll show you a reason why it can't be played, you should check the Logs window as well. Regarding how many tracks to look ahead, 3 is very low, if there is a jingle or station id, it'll be skipped, and you'll only have 2 music tracks which may not be enough to build a teaser.
Thank you for your answer, in the meantime I solved all problems my self, thanks anyway.
I must say it was a bit tricky to get familiar with all the new settings, but I found many new intersting things, GOOD WORK!!
We try to keep compatibility as much as possible between the versions, to maker transition as easy as possible.
