Playlists
eudoeduardo
Seria um divisor de águas se o Rádio Boss lesse e salvasse outros tipos de extensões rot. Seq. Como no Zara Rádio.
Outra coisa muito importante seria poder criar e executar várias playlists dentro de uma mesma. E também várias subpastas dentro de uma pasta.
Please write in English.
It would be a game-changer if Rádio Boss could read and save other types of .rot. Seq. extensions, like in Zara Rádio.
Another very important thing would be to be able to create and run multiple playlists within a single one. And also multiple subfolders within a folder.
I don't think this is needed by the most of RadioBOSS users, I'm sorry.
This is possible, you can reference other playlists inside a playlist - from the menu click Playlist > Insert Playlist.
To run music from folders, you can use the Track List feature: https://manual.djsoft.net/radioboss/en/using_track_list.htm
