Any way to 'overdub' a live stream connection?
VBRadio
I wondered if there is any plans to create a feature that allows connecting to the stream whilst, for example, a DJ mix is playing but have the live connection sit ON TOP of the audio currently playing, with an audio dip?
This would be really handy. i CAN currently achieve the same effect by recording a voiceover link and then running it as an overdub event but that isnt the same as what I want to do here... for example being able to go live on an outside broadcast with an interview whilst music from cloud server plays as a bed?
Thank you for taking time to reply but it doesn’t appear you understand my question. Or maybe the fault lies with how I explained it.
I can and already do stream live. I want the live stream to layer ON TOP of music that is playing on the server.
Imagine with the events and scheduler. I can schedule a jingle to play over the top of a playing track can’t I. I’d love the same option but with live stream too (as example using mobile streaming on phone with iziCast)
Yes, I see. Currently it's set to mute the main stream, and play only the connected live stream. We'll consider adding an option in the future to only attenuate it, or leave the volume as is.
That will be amazing. Thanks. One note, I'm not sure how you'd do this but the option would/should only be available to certain DJs at user level maybe?
At first it's going to be added in the Settings area, so it'll require Settings permission to access it.
