Color changes always
I changed the colors of the fonts here, into black , then he changed it as ist schould be, after a few hours it changed automatically to white again. Then I tried to change it again and restarted radiosboss, gain black so ok, after 1 day they wehre white again, so it ssems he does not save this permanately. Itried also changing it retsrating whole computer, at the beginning it was also black and next day it was white again.
Is this a known issue?
Can you please specify what RadioBOSS version you use, and do you do something before the color changes (e.g. modify settings) or it happens by itself?
HI Dimitry
I changed into Black and it turned into white, I noticed that after I turned it in to black and after a few hours it was white again, i just need to open the settings select style, do nothing there, no changes further and klick OK it turnes into black again
Thank you for the details. Is there anything happening before the color is changed, e.g. computer goes to sleep, or is accessed via RDP?
Hi Dimitry,
Just to clarify: it is not the whole RadioBOSS interface that changes color.
It only affects the upper track display / progress bar area, where the previous, current and next songs are displayed with title, artist and remaining time.
This is the area I mean: the colored song bars at the top of the RadioBOSS window.
After some time this area changes to a white background by itself, while the rest of the interface remains in the black style.
If I open Settings → Style and simply click OK, without changing any setting, this area immediately returns to the black style again.
The computer does not go to sleep, and at the moment I am not using RDP or Chrome Remote Desktop.
Best regards,
Raymundus
More details I tested some different situations, now I found the issue. Radioboss runs on my laptop, wenn I close the screen from the laptop and open it again it changes color also and this is immediately.
