replace track
alexandre
hi stuff thanks for the software very nice! in the future add pls replace tracks?
that is, replace the track in playlist of hard disk, no add track but replace! that replaces thanks
Can you please provide more information on this: what should it exactly do, and in what cases it may be useful?
hi thanks add pic as an example!thanks advances
replaces any track in playlist, from any folder
it does nothing, the software works very well, thanks for the work(y)
You can do it e.g., add a track to the playlist where you need it, then remove tracks you don't need. Separate "Replace" button doesn't seem like a useful addition, I'm sorry. The problem with adding any options is that right-click menu for tracks in the playlist, as well as Playlist main menu have so many commands already, so adding anything new must be justified.
Sorry, I misunderstood your screenshot at first. I thought you were showing a function in RadioBOSS, but now I understand that this is from RadioDJ and you are suggesting the same “Replace” function for RadioBOSS.
Now your request makes sense to me. Replacing a selected track directly at the same playlist position would indeed be quicker and more convenient than adding a new track first and then deleting the old one.
