Fade In/Fade Out noise artefact bug
Do you have any idea what might be causing this problem?
Unfortunately, no - there's no option to "add click on the end" and the fading procedure itself can't introduce those clicks (at least, we didn't found a way how it would have). RadioBOSS 7.2.5 was just released, you can try how it works there.
Hi dmitriy,
Thank you but the problem still present, I try to control all advanced parameters and fade parameters like Parabol of fade etc, but I can't find the problem's origin...
With you're experience, If you have an idea of what can produce that sounds mix bugs.
Best regards
Please disregard my previous reply (if you read it, it's now deleted) I checked the bug tracker and it's already fixed, but the fix is not yet published (7.2.5 has this bug). The next update will be RadioBOSS 7.3 (beta) and it's fixed there.
Dear Dmitriy, Well, Thank you! Have you an idea of the release that.
I Reset by default all the buffer, fade in fade out, touched parabol settings and for the moment the problem is solved.
Can you detail with me the origin of the bug you corrected? Is this linked to a parameter?
Best regards,
Charles
Unfortunately, those actions are unable to fix the bug. It seems a concidence.
The problem is with sliders processing, and a fix included many changes to ensure this may never occur. Due to the complexity of this fix, it couldn't be released in a minor update, so it went to the next major update.
