File Manager Listings Seem to Have Changed
VBRadio
Previously I could select one folder on my File Manager and it would list all songs within there... for example if I have 10 Show Folders then all 10 shows would appear at root level.
This doesn't happen now. Is there a reason why this was disabled/removed, as I found it very useful?
Thank you
Do you mean that your tabs have closed across the Radio Boss Screen. You can open them again they are playlist on your computer if this is what you mean?
Thanks for the help but that's not what I mean. Previously, I could clikc the main Root folder at the top and it would list every single track or jingle within my Cloud files. Perfect to search for things at once or find a DJ mix in a sub folder without trying to remember what subfolder it was in.
Now, when the Root is selected, nothing displays in the right hand column.
** Although as i tested this, I realise that I CAN still search the entire root folder even though the contents don't display.
Now it only shows what files are in the folder itself, not including subfolders, the same way any file manager does it; you'll need to open subfolders to see what files are in there. The Search feature can search in subfolders (click the Settings button to enable it) - when you perform a search, it will look in the folder and all subfolders as well.
