Is there a way to run a scheduler that detects nothing playing and created random generated play list playing?
HMMMM
I have a complicated play list generated by playlists random play and other types is there a way to add one that will notice is nothing is playing and generate one ?
Yes! 😊 If you're using RadioBOSS, you can set up a fallback playlist that starts automatically when nothing is playing.
RadioBOSS already has a feature for this called Silence Detector.
How to set it up​
  1. Open RadioBOSS.
  2. Go to Settings → Options → Silence detector.
  3. Enable the Silence Detector.
  4. Set the silence duration, for example, 10 seconds.
  5. Choose the action Load an extra playlist.
  6. Select your emergency playlist.
  7. Save the settings.
If RadioBOSS detects silence for the specified duration, it can automatically load your fallback playlist. This is an officially supported feature. manual.djsoft.net
Can it generate a new random playlist automatically?​
Yes, RadioBOSS also supports automatic playlist generation using Playlist Generator Pro.
However, there's an important distinction:
  • Silence Detector: Detects when playback becomes silent and starts a fallback playlist.
  • Playlist Generator Pro: Generates new playlists automatically using your rotation rules and scheduling.
The generator can run on a schedule, but generation and playback are separate operations. manual.djsoft.net
What I would recommend​
Because you already have a complicated playlist setup involving random playlists and other playlist types, I'd use a dedicated emergency playlist.
For example:
EmergencyMusic.m3u8
Containing several hours of music selected from your library.
The Silence Detector would activate it only when necessary.
That way, your normal programming remains unchanged.
One question​
Do you want RadioBOSS to:
A. Automatically start an emergency playlist when playback stops?
B. Automatically generate a completely new random playlist whenever the current playlist runs out?
Both are possible approaches, but they need different configurations.
Generally, you should avoid the situation when there's nothing to play - this involves checking your scheduled events, generator templates, etc.
But just in case it still happens, you should use the silence detector: https://manual.djsoft.net/radioboss/en/silence_detector.htm
Silence Detector is the part that notices when nothing is playing. Point it at a short emergency playlist that Playlist Generator Pro has already built, instead of asking the detector to invent a new rotation on the spot. If the main hour mixes several random lists, keep that emergency list on its own track type so it does not reshuffle the IDs you already scheduled.
Hi Clara,
Just curious — are you a real person, or is AI generating your forum replies? 😄
I've noticed that your responses are quite detailed and sometimes repeat answers that have already been given.
No offense intended, I'm genuinely curious!
Best regards,
Raymond
