Hello , first of all to congratulate you for radioboss , I have recommended it to several FM stations and are happy with the system.
I have a doubt about the ad system.
Look . first in future versions should include " If no tracks in the playlist , add them to the queue '.
I've been testing and when I insert a block of advertising in the hours I want to do this:
16:00h Signals Time + 16:00h time announcement + 16:00h Ad + 16:00h Play list generator pro.
But does this:
16:00h time signals + 16:00h Ads + 16:00h time announcement + 116:00h Play list generator pro.
If the ad generator had the option ' If hau tracks in the playlist , add them to the queue' , I think this would be solved .
Similarly, I tried to insert a block of news after the time point . It would be a random list with different cuts, with the purpose of every news hour that list and automatically mixes out news in a different order . How it was feasible schedule for the list not interrupted by the ad and go on the air, just after the advertising block ?
On the other hand as you can insert a list of ads in the track list Ad Generator. This option is disabled. As is enabled?
It would be useful as you place multiple ads from the same advertiser for rotation
Another question I have is if there is a Spanish translation paa ad system .
I may not have explained well , but my English is lousy and I use the google translator .
But does this:
