AutoDJ and DJ statistics
Mike Spencer
AutoDJ and DJ statistics.
Hello team. I consult them. A month ago I am using a Streaming Service with "Sonic Panel". I have an OnLine radio, and therefore I use an AutoDJ system, and DJ's for live broadcasts, configured with IceCast v2. The upload with RadioBoss is perfect. But technically I have a problem:
When I connect as a DJ, I must configure the upload as Shoutcast v1. It connects and emits perfectly. But I can't see the number of listeners online. Any solution?
I would appreciate the prompt response.
Best regards.-
(In Spanish:
Hola equipo. Les consulto. Hace un mes estoy utilizando un Servicio de Streaming con "Sonic Panel". Tengo una radio OnLine, y por lo tanto utilizo un sistema de AutoDJ, y DJ's para transmisiones en vivo, configurado con IceCast v2. La subida con RadioBoss es perfecta. Pero t?cnicamente tengo un problema:
Cuando me conecto como DJ, debo configurar la subida como Shoutcast v1. Se conecta y emite perfectamente. Pero no logro ver la cantidad de oyentes en l?nea. Alguna soluci?n?
Agradeceria la pronta respuesta.
Saludos cordiales.)
You need to configure Statistic Relays to gather statistics from the server: https://manual.djsoft.net/radioboss/en/statistic-relays.htm
The exact configration depends on the server you use.
