Broadcasting to Deva DB90-RX IP Decoder
Stijn Stevens
Is there a possibility to broadcast from Radioboss to a DB90-RX configured as Icecast Source Server with static IP.
What are the parameters in the broadcast setting or is it not possible to do that?
  • db90_rx_tx_set_up_2.pdf
If it supports Icecast protocol, then you need to have the connection parameters: server address/IP, port, mount point. First if pretty obvious, the rest two are configured in the DB90 I guess.
