Bugs in 4.5.3.824
RBS
Hi Dmitry,
I was happy of late to see the forum very quiet. I guess all the bugs are almost sorted in RadioBOSS. ;D
But I have found one in the latest version 4.5.3.824. :P
PlayListGen Pro is up to its old tricks (Like its initial release) of not being able to understand a " " (space) or an "'" (apostrophe).
For example it will filter "Pop80? but not "Pop 80" or "Pop 80's"
So I have had to go back to using 4.5.2.814 which works perfectly. :'(
Regards
All bugs will never be fixed :) New features as well as new bugs are added continuously...
The comment bug is added to the list, will be fixed soon. Thanks for reporting.
Hi Dmitry,
Just checking if this problem has been fixed in this release?
I have installed latest version and am still getting errors in PlayListGen Pro Playlists.
Can send on some screenshots if it helps.
Regards
I'm sorry, Playlist Generator Pro was not changed in this release.
Please give more info on errors. Soon there will be another update fixing many Pl. Gen Pro errors.
