Command in Radio Boss Cloud to scheduler to REINDEX TRACKS
I upload many commercial tracks on daily bases and also delete them automatic by ftp
Is there a command to schedule reindex tracks
like the disconnect or connect command
If you need to update the Music Library then use the menu command there: Tools->Schedule automatic library update. It will create an event to update the library by adding new tracks and removing nonexistent files.
in radio boss cloud i don't see tools?
There's no need to reindex tracks in RadioBOSS Cloud - this is performed automatically there when you add or remove the tracks. You only need to manually use the Reindex feature when you advised by customer support or you feel that it needs to be done.
