Crossfare editor Problem
Davide72
Good morning;
I was hoping that in the latest version the problem of listening to several tracks at once in the "crossfade editor" editing window had been resolved.
I still find that it is not possible to listen to both tracks when I position myself with the cursor at about three quarters of the first file, as shown in the image below... while if I listen from the beginning everything is fine.
Good evening; I see that in the latest version of RadioBoss this problem continues to persist, and it is very annoying because to edit the tracks I can not rely on this functionality, as I can not hear all the tracks at once. But is it a problem that only I have?
Not only for you, the same problem here with 6.1.1.0
Can you please send a screenshot of the Segue Editor window when it doesn't play the files properly? The screenshot should show the starting position of playback.
after the red marking everything is ok, as it should be
EDIT
I tried it one more time and everything was ok
Demonstration effect ? :-)
