Error playback
jopara
Hello, since the last update I am having some problems in the creation of lists.
As I do not know how to explain the problem I put you video link so you can see what happens, which the previous version did not happen.
How do I solve this problem?
Thank you
https://vimeo.com/337725425
venespain73
Hola, por lo que mencionas quieres que suene lo que tienes programado y luego se monte otra programaci?n (por lo que he visto en el v?deo), eso es muy facil, simplemente tienes que decirle al RadioBoss que espere (TIEMPO M?XIMO DE ESPERA EN LA COLA X ejemp: 10 min) y le dices que se coloque al final del playlist, creo que eso resolver?a tu problema de todas formas si lo deseas escribeme por facebook y ahi organizamos para ayudarte, saludos me buscas como Naudy Landa Frederick
jopara
https://vimeo.com/338283303
I will try to explain it to see if the google translator does it well (or me).
You see, every half hour I launch a new playlist that is as follows:
1.- JINGLES TIME (this clip would erase the previous list)
2.- LITA WITH NEW FASHION SONG (this list is marked: if there is a track in the list, add them to the queue)
3.- JINGLES AND PRESENTATION OF ANNOUNCER (If applicable, also marked as: if there is a track in the list, add them to the queue)
4.- ADVERTISEMENTS (marked as: if there is a track in the list, add them to the queue)
5.- NEW LIST (marked as: if there is a track in the list, add them to the queue)
In the latest version of RadioBoss, before this update, the lists and / or tracks were added one after another (because the box is checked: if there is a track in the list, add them to the queue), but now the jingle hour, delete the list and place the number 1 in the list, when option 2 is loaded, it is loaded afterwards (because it is marked: if there is a track in the list, add them to the queue), but the start of this new list puts number 2 on the list and jumps everything he has before that second position and so with all the new tracks that are added.
I do not know if he speaks to me well explained. I upload new video so you can see how RadioBoss proceeds when loading the new list.
Thank you
The description is clear enough, thank you. It looks like a bug, please install an update (RadioBOSS 5.8.5.2) to fix it: http://dl.djsoft.net/radioboss_setup.exe
