Thank you for your reply.
The attribute can however be mentioned in the title section ? and with parentheses ?
Example : For me Formidable (Feat. Pascal Obispo)
You can change the title format for the playlist in Settings->View, and for broadcasting in Settings->Broadcast. Use the %comment variable to include the comment field contents.
Yes thanks !
My question concerns the concept of rules for spacing artists present in featuring.
Can the attribute be mentioned in the "title" section? And with parentheses?
Or should it be put in artist?
Because afterwards otherwise I'm afraid that radioboss thinks it's a different title and plays it twice but by another artist.
How do you recommend doing ? If you can put an example with the "Feat." attribute.
If you plan to use the repeat protection feature in Playlist Generator, then you need to specify artist in the Artist field. It will be able to separate artists, so "Artist1 feat. Artist2" is treated as two separate artists.
You can find more about it here: https://manual.djsoft.net/radioboss/en/settings2.htm
Last question I did not find the answer.
How to do when there are several artists featuring.
Example :
Forever Gentlemen Feat. Corneille Feat. Vincent Niclo Feat. Roch Voisine
or
Forever Gentlemen Feat. Corneille; Vincent Niclo; Roch Voisine
