Fraunhofer aac-lc
Kevin H
I would see an addition of fraunhofer codecs in the encoder. I miss AAC-LC. better quality, we already use it live now we want to see it in radioboss.
AAC-LC is called "AAC" in RadioBOSS. Please also note that you can use custom encoders with RadioBOSS: https://manual.djsoft.net/radioboss/en/custom-encoders.htm
Fraunhofer is available as command line utility, and IIRC it's also available in FFMpeg utility.
I have no idea how to use the fraunhofer aac. Could you help me with the command line.
Have you tried the AAC option in RadioBOSS, or maybe AAC+? Doesn't it work for you? Setting up custom encoders makes sense when you have a specific problem you need to solve.
Kevin H
Fraunhofer's AAC LC is of better quality than the regular AAC. We use it in our encoders. I wish radioboss could do this too. Can't miss this for professional use.
When you select AAC/AAC+ in RadioBOSS do you notice any quality degradation?
Kevin H
My stream is going through orban sound processing. The standard AAC open source is less secure. A nice addition to radioboss as a professional playout system.
Fraunhofer's aac at 128 kbps is already of a higher quality. aac+ comes after the sound processing.
RadioBOSS uses ffmpeg to encode AAC/AAC+, as far as I know internally it uses Fraunhofer.
You can use any encoder that supports command line I/O with RadioBOSS in case there's a need for this.
Kevin H
Can you give an example of the command line. I saw the custom encoders page. I can't do it with the command line.
Kevin H
Maybe?
C:\Program Files (x86)\RadioBOSS\Plugins\ffmpeg.exe -loglevel -8 -f s16le -ac {Channels} -ar {SampleRate} -i - -c:a aac_low -
mime type:
audio/mpeg
My wishes:
aac-LC fraunhofer
44100
128 kbps
2 channels
Which rule?
Sorry for my english
You can try it.
Still, I'm not sure what problem you're trying to solve. What's wrong if you use the standard AAC/AAC+ option in RadioBOSS?
Kevin H
The quality of aac lc from fraunhofer is better than the standard aac codec.
For more information fraunhofer website.
They are codecs for professional streaming.
In radioboss is aac faac ?
Depending on what RadioBOSS version you use, there may be different encoders. Current versions (released in the past couple of years) do not use FAAC. It uses ffmpeg and internally I suppose it's Fraunhofer.
It says professional playout but this is really missing under professional.
What is actually missing? I really don't understand what problem you're trying to solve. Did you experience any actual quality or other problems with AAC in RadioBOSS?
