Paul Webster
This is a slightly unusual question.
I have a plugin for Logitech Media Server (LMS) that tries to show additional information when a user is listening to a radio stream.
For example - showing cover art for the track that is now playing.
For streams that play via radioboss there is a naming convention
<serverid>.radioboss.fm/stream/<useridwithinserver>/stream (or similar)
From that I can make an API call to query things ...
<serverid>.radioboss.fm/w/nowplayinginfo?u=<useridwithinserver>
However, I do not see a call that I could make that would return the station info.
In other words something like
<serverid>.radioboss.fm/w/stationinfo?u=<useridwithinserver>
or
radioboss.fm/w/stationinfo?s=<serverid>&u=<useridwithinserver>
ideally it would return the same data as the search results - but for a single station ... something like
where the id fields are replaced by real values ... although I can generate most from the URL ... but then I would be able to show the station name and description.
Is there a call I could make ... or could you add one?
or
{ "name": "Station Name", "description": "Station Description", "path": "xxx", "genre": "Pop", "url": "https://somewhere", "links": { "m3u": "http://<serverid>.radioboss.fm/playlist/<useridwithinserver>/stream.m3u", "m3u_ssl": "https://<serverid>.radioboss.fm/playlist/<useridwithinserver>/stream.m3u", "pls_uri": "<serverid>.radioboss.fm/playlist/<useridwithinserver>/stream.pls", "http": "http://<serverid>.radioboss.fm:80<useridwithinserver>/stream", "ssl": "https://<serverid>.radioboss.fm:180<useridwithinserver>/stream", "port80": "http://<serverid>.radioboss.fm/stream/<useridwithinserver>", "port443": "https://<serverid>.radioboss.fm/stream/<useridwithinserver>", "page": "https://<serverid>.radioboss.fm/u/<useridwithinserver>", "artwork": "https://<serverid>.radioboss.fm/w/artwork/<useridwithinserver>.png", "stationlogo": "https://<serverid>.radioboss.fm/stationlogo/{{@user_id}}.png", "api": "https://<serverid>.radioboss.fm/" }, "streamlink": "https%3A%2F%2F<serverid>.radioboss.fm%3A180<useridwithinserver>%2Fstream", "stationlogo": "https://<serverid>.radioboss.fm/stationlogo/<useridwithinserver>.png" }where the id fields are replaced by real values ... although I can generate most from the URL ... but then I would be able to show the station name and description.
