How to start record by a commando in the scheduler?
tieffeitalia
Hi... I need to record an internet stream that is programmed to start by the scheduler... I need to start recording when the event start, and stop recording when the event ends... but I can't find a "startRecording" or "stopRecording" command... it's possible to do it?
Thanks,
Tieffeitalia
tieffeitalia
Hello, thanks for the answer.. but.. I tried it, I set it to take the sound from Audio Mix.. I'm not streaming, just playout on my own computer...
I schedule the event that load an external stream from the internet... Just after load the stream the scheduler in programmed with streamarchive command.. but the mp3 file that results from the record is blank... no audio... What I did wrong?
Thanks a lot,
Tieffeitalia
When recording from Audio Mix it will record what is playing in RadioBOSS. What RadioBOSS version do you use?
