After updating to latest version (6.2.2.0) The playlists folder .m3u8 do not play. Everything was perfectly working, now it say "INSERTED 0 TRACKS FROM .... ) It will open fine when I click open file... but when I restored from backup it doesn't. Folders are located in separate HD. Please help. If I go one by one on the playlist, and rename the playlist to "b" at the end, it will work fine. The problem is that I have many different playlists for the entire week (at least +30 per day) . Please help. Maybe is a common error and kindly ask for fix solution. Thank you
