Is there a way to bulk assign Ad Properties?
Bjorn
Hey there, I've noticed you can select a few boxes at once when assigning ad properties, but I can't figure out how to bulk delete or add...
I'd love to be able to select a block for the whole week and assign/remove an ad to it... Both horizontal and vertical.
Cheers,
Bjorn
Although... it would be cool to be able to assign ad properties to multiple ads at once. So select a few from the left column, then hit space bar, and then they all get assigned that block.
See in screenshot.
I don't think that would solve this. It's random what and how many ads I want to assign to a block, so being able to select multiple and then hit space bar and have them all assign as above would be super helpful and save loads of time
If this is needed for the new ads, you can probably create several typical presets, that you will use as a starting point when a new ad is added. I'm not sure yet if the feature to edit grid for multiple ads at once will be added soon, I'm sorry.
