Keeping tracklist series intact following upgrades
We use a lot of program series where we draw files in order from directories containing up to 60 episodes. When broadcast sequentially RB keeps track of the ones already used and plays the new episode in the series. This information is lost when RB is upgraded to a new version and all the series revert to Episode 1. Can RB store the status of these playbacks so we do not have to go through numerous program folders, determine which episode was last played, and disable them so they wont "reset"? This is really time consuming.
This will only happen for major updates, we've also changed the way it saves the position, so from now on the position should be kept if you update from version 6.0 to any other future version.
