metadata over tcp & utp
Kevin H
Veel professionele stream-encoders hebben deze functie als invoermetagegevens.
Radioboss staat op een aparte server.
Is er een optie om het via tcp of udp te verzenden?
Oh sorry, the translation went wrong. Is there any way in radioboss to send my metadata in tcp or udp. I also stream with two external encoders with separate sound processing. They receive it in that format.
Where can you find that php file?
The requests are sent to the scripts that you create. The purpose of the script depends on what you want to do with the notification, and it's not necessary to be a PHP script.
