Music levels
timgreb
Can you tell me what I have changed?  When I key up the mic the music gets louder and when I turn off the mic the music goes back to it's normal volume, I have tried the settings in the INPUT box
I guess if you could tell me what the settings should be at to keep the music at the same volume when the Mic is on or off.
Thank you
The setting is located in the Inputs section, MIC button, "Music Level" - set it to 0dB and the music level will remain the same when you activate and deactivate microphone.
