NICKY G DJ
what is the difference and the practical use between generating an automatic playlist, and that of generating a playlist and saving the various files then recallable ??
What is the most correct and correct method to use?
What's the advantage of generating many time playlists in * .m3u8 files (01.m3u8; 02.m3u8; 03.m3u8 ....) and then recall them with the scheduler command ...
Is it not easier to generate a playlist based on the chosen preset and broadcast it?
