Não funciona
It makes the recordings but then doesn't search for the files.
It inserts a voice track only after the selected music track. In case of empty playlist, it will not work. We'll change it in the next update, when nothing is selected, it will insert to the end of the playlist.
Ok but how do I insert the songs into the playlist, I have to do something but it simply doesn't do anything.
The remote voice tracking module is not yet able to add music. It only allows to add voice tracks to existing playlists, rearrange and delete music tracks. We'll extend its features in the future updates.
Hi good morning!! When I said songs I meant voice tracks, I can't put the voice track in the playlist, is there a tutorial for this?
You can add a voice track, but you need to select a music track in the playlist first - the voice track will be inserted after it. If this doesn't work, what error message does it show?
