Most of my playlists are generated such tat the last song in an hour ends with in a minute of the top of the hour. If I have sweepers enabled for those times where this is not the case, the substitutions are welcome, after all, that is the point of the feature. However, in cases where things are timed perfectly, a sweeper is still inserted. In some cases the substitution is just as good, but in other cases, a last minute song substitution has caused problems.
For example, it is impossible to confidently announce a set of artists up to the bottom of the hour, and segments like double plays, or cover comparisons are interupted. So before radioboss adds a sweeper, could it check to see if its even necessary?
Thanks for your consideration.
