problems with audio plugin
KarlZ
We're gonna using a new server for our webradio, but actually There's some problems.
Actually we are using Radioboss 3.0.0.350 With Stereo Tool 2.10 and Icecast 2.3.2 , and it works fine, but I don't understand why, on the new server, as soon as Stereo Tool is unable, buffer problems happen. Everything works fine when it's disable...
We have test other audio compressor, and the same problem happen...
I have test Stereo tool with another audio software, and everything works fine, so the problem seems to came from Radioboss... could you help us?
Hello!
If it worked on the old server, then it should work on a new one as well.
And what does it means "buffer problems", you got repeated samples, sound is corrupted, or else?
Do you use latest version of StereoTool?
You can send a whole RadioBOSS folder to us (support@djsoft.net, pack it to ZIP archive) so we can look what's going wrong.
