Radio Boss does not keep schedule if shut down
smcalpine
Hello everyone.
I am running 6.0.4.0 and we had a brief power outage last night. When I restarted Radio Boss. my entire schedule was gone and I had to recreate it. In previous versions , this wasn't a problem. I would start the program back up and it would start where it had left off.
I believe everything is configured correctly. I double checked, unchecked and rechecked, but dont want to restart anything and have to schedule everything all over again. Here is a screenshot of my configuration
Any help would be appreciated! Thanks is Advance!!!
S
There's a chance that one or more of the settings files (including the files where playlists, events etc are stored) will be corrupted because of power loss, please see this post for more info: https://www.djsoft.net/community/th...where-the-application-crashed.7173/post-35546
It's not that it's a problem with the newer or older version, it's how Windows works. As a rule, you should avoid power outages by using the UPS and correctly shutting down the PC. Creating backups is a good option too, you can do it manually from the Settings menu or schedule automatic backup creation using the createbackup scheduler command: https://manual.djsoft.net/radioboss/en/scheduler_commands.htm
