Radio Boss System Settings did not restore
KBRadio_THP
I had a power outage here, less than an hour ago, and when it came back Radio Boss Ver        When back to default settings.  All configurations seem to be lost?  I tried to do a system restore from the setting drop down, but it did not locate any files apparently.  Is there a direction or folder I should be looking for to assist restoring.  Really need everything back that was lost
It appears that files were physically removed due to power outage. If you don't have a backup copy, then I don't think it would be possible to restore.
Well not the answer I was hoping for, but live and learn.  I now know I should be backing things up..  Thanks for the quick response.
You can use the Settings->Settings backup and restore to save your settings to a single file. You can later restore settings from this file.
