Radio boss se vuelve modo de fabrica
perucanta
¿Hay alguna forma de evitar que radioboss se abra en modo de fábrica cuando hay un corte de energía? Me paso que al fallar la luz no habia configuracion, me salvo porque tenia un respaldo de el.
perucanta
Por favor escribe en ingles.
¿Hay alguna manera de evitar que radioboss se abra en modo de fábrica cuando hay un corte de energía? Me paso que al fallar la luz no habia configuracion, me salvo porque tenia una copia de seguridad de la misma.
perucanta
Please write in English.
Is there a way to prevent radioboss from opening in factory mode when there is a power outage? It happened to me that when the light failed there was no configuration, it saved me because I had a backup of it.
This could happen due to "write caching" used for the disk, this improves performance, but in case of power outage, the data can be lost.
You should either disable write caching in Windows options (not recommended because it hits performance) or use UPS or other solutions to prevent computer being powered off.
