Radio Caster and logger security
Andama
Hello everyone, I love RB security features but radio Logger and Caster can't be protected by password, several times I found Radio caster or logger is accidentally closed by my Station DJs which disconnect online listeners while RB plays music to only those listening on local transmitter.
How can I secure Radio Logger and Caster as I would to RB so that no one can close it by mistake?
If one is determined to close it, they can do it using Task Manager or other means. If you want to protect it from accidental closing, you can disable the "Show button on taskbar" option, so the software will only appear in the system tray.
Andama
Yes, it worked
