RadioBOSS 6.3 [beta]
What's new
  • Containers: pack one or more playable items into a container; container appears as a single item in the playlist
  • New crossfading option: Mix Start determines where the following track is mixed in; mix start can be automatically detected
  • Hour separation markers in the playlist (to enable, right-click a playlist tab)
  • New storage option for additional information: store information in a separate file (details in the user manual)
  • Added support for .cue files: track title is updated according to the information contained in the cue file
  • Track List: next track in Track List is evaluated when the item is selected in the playlist (and Track Information panel is enabled)
  • Weather data display in main window improved: now it also shows wind speed
  • Overlay events: ability to send playing track titles (option in Settings->Scheduler)
  • User access control: added permissions to turn streaming on/off and delete profiles
  • File Explorer tab: added "quick access folders" feature (right-click any item in the file list to enable it)
  • Stream archive feature redesigned
  • Stream archive: added an option to record stream without applying DSP
  • Stream archive creates .cue file with track titles
  • Nowplaying artwork export can be done in JPEG to reduce file size
  • Added ability to name HTTP requests
  • Jingles: allow playing only one jingle at a time (option)
  • Teaser: added filter by Tags
  • Log: added right-click command to jump to correcponding playlist item
  • Added option to show default image when video window is visible but audio file is playing
  • Settings->Controls: ability to disable turning off the scheduler
  • Auto Intro: added "Not include" filter for tags
  • API security option: allow only local requests
  • Added "Set cast title" command in Tools menu to send custom streaming title to servers
  • Added option to configure icon size in the playlist (Settings->View->Style)
  • Added %startsec and %endsec title format variables that hold playback start and ens positions for playing track
  • Advanced option: relay volume when overlay event plays with "Priority over relay" option
  • Advanced option: volume slider only affects main sound card, not monitor
  • Tracks played in cart machine and AUX players are now logged and included in the reports
  • Accessibility improvement: added ability to sort list (call the menu by pressing Shift+Menu key)
  • Inner playlists are opened in advance, this allows proper next track title evaluation and crossfade calculations
Music Library
  • Added right-click commands for tracks: move to library / copy to library
  • Option added: what show in the file name field (file name and path or full path)
  • Improved tracks processing window
Track Tool
  • Ability to record voice insert from Track Tool
  • Voice insert can be prelistened
  • Expiration option for voice insert
  • Playback level configuration for voice inserts
Scheduler
  • Event execution progress for download, generate playlist and makelibrary commands, accessible from List (button on the scheduler tab)->View running tasks menu
  • Added "dsp" command to enable or disable all/specific DSPs
  • "next" command with "CueNextOnEnd" modifier can be used as a first action in multi-action events
  • DTMF exit option: allow to finish playing selected file types (e.g. commercials) instead of terminating event right away
Ads Scheduler
  • Backgroung color can be set for ads to mark them in the list
  • Items in the ads list can be manually reordered using dragging
  • Allows to minimize groups in the ads list
  • Option to pack ad block into a container
  • Reports made in profiles other than default include profile name
Report Generator
  • Added support for styles
  • Total duration is calculated for "List" reports
  • Command line to automate report creation (details in the User Manual)
  • Added keyboard hot keys (arrows) to manage rotation and categories
Segue Editor
  • Prev/next buttons to quickly move to other playlist items
  • Fixed bug when track movement to the left wasn't possible at some positions
Bugs fixed and minor improvements
  • Improved start time calculation in the playlist
  • Detect mix point feature in Music Library (and makelibrary command) improved to have minimal mix value, as set in Crossfading window
  • Fixed a bug in Search feature (player and library)
  • Fixed a bug: in rare cases fade out lead to high sound level at the fade end
  • Fixed: search by tags sometimes didn't work properly
  • Fixed various localization bugs
  • Fixed: tracks played in Overlay were not included in reports
License key
The free key expires June 15, 2023.
RadioBOSS 6.3 beta:
x86 https://dl.djsoft.net/beta/radioboss_setup_6.3.0.6.exe (4/19/2023, 34MB)
x64 https://dl.djsoft.net/beta/radioboss_setup_6.3.0.6_x64.exe (4/19/2023, 38MB)
Bonjour,
Pourquoi on ne peux pas faire démarrer la lecture aussi par une commande exterieure via port usb ? Vous aviez dit, il y a deux ans, que cela serait bientôt disponible.
Merci.
José - Radio Altitude
Hello, I would like to see the update of the function that shows the next audio in reports playing now, ignore audios like vignettes, commercials, ids... show only current music and next music.
se detiene cada 50 minutos no cotinua con la lista de reproduccion por mas estar activado la lista de reproduccion
Suggestion a function to allow 3rd party software like Virtual DJ so you do not need to use Virtual Audio Cables would be nice
x86 https://dl.djsoft.net/beta/radioboss_beta_6.3.0.0.exe (3/17/2023, 32MB)
when downloading it, the "Avast" antivirus detects it as a virus.
I made a streaming recording and it got stuck during the recording, and in the streaming recording configuration in the codec part I put 48000 and the recording was at 24000
Merci.
Please write in English.
This is planned for one of the future update, it was supposed to be included in this one, but it's not ready yet.
This is a false detect. You can ignore it.
Hello. My subscription expires in a month. Do I have to ask for a beta key?
No, you can use it with your key.
Please send a screenshot of the Stream Archive settings, we'll try it here.
Connecting with other audio software (if you want to transfer/receive audio) is only possible via virtual audio cables - this is the most universal solution, any other solution will require specific changes in both programs that need to connect.
Por favor, escriba en inglés.
Se detiene cada 50 minutos No continúa con la lista de reproducción Independientemente de cuánto tiempo esté activada Esto sucede cuando se activan los datos de tiempo Lo lleva a la lista de reproducción y se detiene
Isso está planejado para uma das atualizações futuras, deveria ser incluído nesta, mas ainda não está pronto.
Esta é uma falsa detecção. Você pode ignorá-lo.
Não, você pode usá-lo com sua chave.
Por favor, envie uma captura de tela das configurações do Stream Archive, vamos tentar aqui.
I already asked about this possibility and you answered "It's about to be released, so this feature goes to next update like 6.2.1."
Is it possible to include this in the upcoming version?
Before the final version, is it possible to add a cell coloring option to the ad block? So I can indicate which blocks are occupied (e.g. some show). So the marketing manager doesn't put ads at this time.
Since I can't set different times in the block, this could be a good solution.
Can you please specify what stops?
I just installed it and when I run it I get the following error.
It looks like the antivirus removed some files that were installed, or it prevents it from running. There's nothing we can fix from within RadioBOSS, the issue is caused by Avast.
It's not available in this version, I'm sorry - but now it's possible to color ads in the list.
