RadoBoss Freezes, Stutters, Skips
grasfire
I have encountered a problem in the recent 2 weeks. RadioBoss will freeze or stutter during broadcast. When this happens the CPU % in the status bar of RadioBoss will jump to 75%+ yet, in the task manager I'm only using between 5%-10% for RadioBoss and the computer itself is only using 30% or less!! I don't understand why this is happening. The problem may last anywhere from 30 minutes to several hours!! This is not good, because it causes my schedule to get off dramatically... We're talking as much as 20 minutes!!! NOT GOOD!!![/b]
Any suggestions?!?
To the best of my knowledge nothing has changed! I'm doing exactly the same thing I've done since the new computer was installed in July...
When CPU meter in RadioBOSS shows big numbers while task manager shows low (like in your case), this means only one thing: the network connection is not fast enough to send the stream.
Stuttering happens because RadioBOSS pauses waits for data to be sent before encoding next portion of data.
You should check
- your ISP... they may changed something and upload speed decreased.
- stream hosting provider - maybe their network or servers are overloaded.
As you have advised I check my ISP
  I have an upload speed of 1MB+
  The stream server has a 3% or less load
I also have discovered that even if I turn off the Broadcast on RadioBoss that after about 30mins of playback, it will begin to have some latency.  It will not stop or stutter like during broadcast, instead it has a slight echo or sound like its underwater....
Any further recommendations?!?
Sorry for a delay... was checking on this issue.
As we were unable to reproduce it, I suggest you to reinstall the software to a different folder - this will reset the settings and probably the problem will be solved.
If you hadn't already done so, please update to the latest version: http://dl.djsoft.net/radioboss_demo.exe
I did a complete unstall and reinstall...
RadoBoss is once again working!!! ;D  Once again everything is working perfect!!!
Thanks for your help! 8)
